Thanks for tagging developers.
I’ve removed all NURBS in my file but I still get speed reduction.
I saved my material and make a new file by imported all my parts without nurbs, and rebuild my animation opening with same lights and material. It seems to not have speed reduction.
I’ll continue to rebuild my scene and launch rendering step after step to figure when rendering time drops.
I’m guessing if it could be something linked to huge amount of datas duplicated/deleted in the file and multiple incremental saves that could corrupte the file, but I have some doubt.
Best
EDIT : After rebuilding my file, it seems that is still an issue with the planar lights. I’ve added my planar light to my scene with curve powered material and that makes the sample rate drop.
I added a standard plane to see if an area light makes same behaviour and I copy paste the planar light material (to keep the power curve) to the plane, then make the render and sample rate came back to normal. Maybe something linked to the ‘geometry’ of the ‘planar light’ object.
EDIT 2 : I should miss something, use planar with planar light material doesn’t change speed reduction but area light with curve animation for power works instead of curve powered planar light.
